Let's fix this interior!
bigro007
Je parle français un peu. I took French in high school, but it was long ago. Your English is fine. Just needs a little punctuation! Where you from? French-canadian? Straight up French?
i'm french from philipsburg quebec. My vision play me some trick and i forget word in both langauge sometime so yes i"m a bit sorry if some of these thing are missing most of the time i notice them only when i post the thread which is a bit to late and what about you from us or canada?
blk\blk90
TX
A little progress today. Big thank you to @TimboSHO for getting me some much needed parts!
Radio bezel and radio are in! I turned it on but have no sound and the CD player doesnt turn on.
20190104 212516
So here's the situation in the trunk. Just like it left the factory!
20190104 212554
Drivers side trunk. Stupid fat fingers.
20190104 212612
Pass side trunk. No fat fingers.
20190104 212618
So I moved on to change our that hideous, 2000 civic dx ricer shift **** with a different one(thank you timbo!), and found this. A homemade attempt at a short throw shifter I guess. I'd really like to meet the guy who owned this car and made this mess and beat the **** out of him.
20190104 211559
But this arrived today so I guess it's ok. (Thank you @LOUDSHO92!)
15466597624216173100062292879348
So my concerns now are this:
Do I need to get a factory amp and resolder the hack job?
Or do I just buy an aftermarket deck and make it work?
There's lamp cord(seriously) running to the fronts and the rears are just hacked in. I'll run an FM transmitter to keep a factory deck so I'm not to concerned with that yet. I'm just tired of hearing the busted ass suspension rattling around!
So with the rod shifter will my shift boot work? It looks like it's missing something. The boot isn't flush with the console and doesnt have a plate/ring on the bottom. And there was a thread about welding something to make the rod shifter less sloppy? Or drilling out something and doing something? Where is that happening?
15466603708132213490192922183111
Thank you in advance for dealing with my myriad of questions and problems. But I know you guys are just as happy as I am keeping another SHO on the road! Well, maybe not AS happy as me, but you know what I mean...
sperold
Last to Know
There are a lot of articles on the factory set-up for the radio on this forum, so you should be able to have the original system if that is your goal.
I got a lot of help from SV&HODan when I rescued mine.
If you plan on running the stock setup obviously the wiring will have to get back to stock configuration and you will have to figure out what the stock configuration was. Not sure if that year was all JBL with sub or not. I forget over the years. There is some info in this thread
https://shoforum.com/index.php?threads/ford-taurus-sho-speaker-diagram-needed.84952/
If it came with a factory sub you may have an issue finding one that still has good paper and surround due to age. There is a way to replace the speaker with aftermarket in the stock enclosure. So if stock setup is important to you you can explore this.
If it were me, I would get a more modern setup and enjoy it more. Personal preference in appearance at this point. I'm sure the speakers are not still all original due to age and previous owner doing stuff to it with lamp cords.
blk\blk90
TX
I'm not too concerned with appearance. I'm pretty sure I have the amp bypass so I might just go that route. I had some top of the line Sony xplodes I can see in the rear. That's all gonna come out.
blk\blk90
TX
This link should help with your rod shifter replacement. Shosource has replacement parts for the rod shifter if they are loose at the joints. If you got the shifter from Loudsho, they may have already be upgraded, you can ask him.
https://shoforum.com/index.php?threads/how-to-convert-your-sho-to-a-rod-shifter-pics.81792/
I've read that post many, many times already. I have a pretty good idea of what to do. But one thing I do best is mess things up so we'll see how it turns out.
