My questions are is is worth it to get a Tweecer or a Moates quarterhorse tuner at this point with my car.
3.2 swap
BBB, PnP
y pipe
UDP
(in case you didnt know)
I have a set of heads that I pulled off my 3.0 that are getting ported, polished, valve work, new valve stem seals, and possibly SHOshop stage 2 cams.
Now I do realize that I kind of need tuning for the cams for the raised idle and such but is it 100% needed?
If I dont get cams can I pull any power out with tuning?
Do you know any internet articals that I can read about tuning. Stuff I need to know. I want to know not only the basics but say for instance adding timing or adjusting the MAF for a bigger MAF.
Also are the 3.0 heads and the 3.2 heads have the same sized combustion chambers?
3.2 swap
BBB, PnP
y pipe
UDP
