leaking o ring need help
bulldogs3d
new york
well i have a leaking o ring were the oil filter screws onto the motor ford canot locate the part and says this rarley happens has this happened to any of you and do you know i can get one i would really appreciate the help i'm leaking very bad.
Rockledge
Pluggin' away
Connecticut
You might have to make your own. I recall reading about this problem once or twice before so you might want to hit up the search function.
bulldogs3d
new york
i guess there is one on the motor 2 i brought my car to ford 2 change my tranny pan seal and had them check the oil leak out also they told me it was this o-ring and they cannot get it i'll have to look at it a little better when i pick it up tomarrow but it will be very funny if it's the seal on the oilfilter because these are the well trained "ford mechanics" lol
SASHO91
Zoom Zoom
San Antonio,TX
more than likely its the oil filter seal....
allthough it may in fact be the oil cooler-block seal....
bulldogs3d
new york
is that were the that seal is located because all they could tell me is it's the o-ring they have a part number but it's on my invoice i will pick up tommarrow
bulldogs3d
new york
just so i don't have to ask later if it is the oil cooler-block seal is that avail anywere?
e_clouser
04DrpTopGT
Near Harrisburg, PA
I have had the same problem, infact Ford failed my car for state inspection because the oil was hitting the exhaust. I searched for the replacement o-ring to no avail. I then took the oil filter housing(oil cooler) off got the old o-ring and went to several stores till I found one that would fit. IIRC I got my o-ring at the local hardware store in the plumbing section. Took me a bit to find but not impossible.
Eric
Off Road SHO
Moderator
There is also a hidden captive o-ring inside the oil cooler. It seals around the hollow bolt that holds the cooler to the block. Also hard to find. Like said above, take the cooler to any hardware store and get a round 0-ring that's close. The original is a flat gasket, I believe. You might be able to use a flat gasket from an oil filter also.
Tom
AREA 91
PA SHO SHOP
Area 91
From www.shonutperformance.com
V6 Oil Cooler Bolt to Block Gasket (obsolete) E9DZ-6749-A 28.49
V6 Oil Cooler to block Gasket E9DZ-6L621-A 13.09 13.09
The first listed is the smaller o ring.
The second is the larger o ring. This is the one you need.
:thumb:
SHOtimer
#2910
Santa Clarita, Ca
:thumb:
You beat me to it! He has several in stock - (in fact I just bought 5) so he should be able to help you out just fine.
Doug
bulldogs3d
new york
thanks alot guys i was gonna try the hardware store thing over the weekend nice to have something hat just fits :hail:
