Leaking Brake Fluid Mystery 94 ATX
gurucomputers
Everett, WA
Add infoLet me start off by telling what has been done. First off I had a MC leak at the bottom and I needed new front brakes. Saturday I take it to my brake guy at Les Schwab who has been doing all my brake work for many years. I had them replace that MC and a complete front brake job. New calipers, rotors, and pads. The rear were done about 5 months ago. I get it back all is good until Monday night. I am sitting at a red light and notice the pedal is slowly going down. Hmmm so I pull in to a gas station and pop the hood and sure as @#$% the MC is half empty. I top off the MC and go home. The MC was full when I got it back. The MC is not leaking or any of the calipers and wheel cylinders. What could the fluid possibly be going?
sho-n-tell
north cackalacky
im no sho guru fo sho! but check the cruise deactivator switch on the bottom of the mc,this is a culprit to alot of other problems also.mine was leaking and shorting out my fuses which caused me not to be able to take car outta park and no brake lights.im sure somebody will give you the right solution if its not your deactivator switch.i just bought one last week about $30 at dealer ship.and thanks to the forum for helping me out again!
gurucomputers
Everett, WA
The MC was just replaced as well as the CC disengagement switch. I've looked and felt all around the MC and no leaks there. It's going back to the shop tomorrow to be checked out...
ATX has a CC cancel, MTX does not. Which tranny do you have?
ATX
gurucomputers
Everett, WA
Leak Found
OK, heres the skinny. I was under the impression that the CC switch was replaced with the MC. That was not the case. The fluid is leaking from inside the switch out the bottom and running down the wiring harness. Does anybody know a P/N for the CC switch mounted under the MC. If I go to the Dealer I'll have to wait til Monday.
Racer X
SHO Pilot, Retired
Connecticut
It's being sucked into the brake booster, if it's not leaking from somewhere else.
sho-n-tell
north cackalacky
i had the receipt a few days ago but ford should know the part by the name "cruise control deactivation switch" they now have a adapter plug so there is no spliucing of the wires also.you can try this number well there are 3 numbers on the wire, 4w1t,14a411,p2609. hope that helps.its like $27 and change
gurucomputers
Everett, WA
Important "Potential Fire Hazzard"!!!!!
Just an FYI for those who are still using the old style.
You hit it right on the nail. I just picked it up from Ford. They have replaced the old style switch with an improved one. He ran my VIN to see if there was a recal on it but there was'nt. They have replaced the old one with a new one due to potential fire hazzard. He said the fires are more common on the F series trucks but has seen a few with the Taurus. The new style comes with an adapter cable which plugs into your harness and to the new style switch. I will post the part number for the new switch in a bit.
dan.delargy
