Lamp Out Indicator
Tommy's SHO
SHO Member #535
Montréal, Quebec - Canada
So when does the "Lamp Indicator" light light up?
I noticed that the passenger side inner brake light was out today and the "lamp out" indicator never indicated it to me.
Is it only for the turn signals or headlights?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
My lamp out indicator comes on when I've got a brake light out or a turn signal out (flashes on and off with the turn signal).
MilTownSHO
Horicon, WI
Never seen the turn signal but seen it whenever you are applying the brakes if that's what's out. If it's a headlight or running light it will just be on whenever the lights are on. :thumb:
ScotSHO
Lewiston, NY
The lamp out only works on the outer brake lights, the inners are not monitored...
yamahaSHO
E85 whore
Arkansas
I had a corner blinker out and the indicator did not light up. It did light up when my headlight was out.
opalmtx
douglasville,ga
I've got the opposite problem, the light stays on all the time on my wife's 96 and no lights are out.??????
Markus
Ottawa, Ontario, Canada
autobahnsho said:
It also comes on when you're low on wiper fluid and you try to use the washers...
Not on my Gen II. Low washer light is a separate bulb from the lamp out warning. Are Gen Is different?
Markus
Either the lamp out warning module is bad or the wire between the module and the instrument panel lamp is shorted to ground.
