Know anything about it?
12hournighshift
USA
Problem- speedo or tac make a sound that bothers me. Kinda like rubbing marbles togeathe, I think it is even ceating some false speed readings.
What would be the best way to fix it?
Would it be a good time to buy a dash brazel? for a two birds with one stone effect.
Gez89SHO
LEGO SHO
NE Philadelphia, PA
Speedometer cable ran dry and it's making the noise, it's noticeable in lower speeds mostly. You need to **** speedo cable with speedo cable **** (or grease).
TYSHO
Earth
I thought it's recommended to use graphite ****?
Rockledge
Pluggin' away
Connecticut
When I had my dash pulled back and cluster off this weekend I took the opportunity to **** my speedo cable. I used PB Blaster's "TDL" (Teflon Dry ****) and it worked great, no more "fluttering" sound that I used to get.
