Knock sensor numbers and availability
Acuronda
WA
I am not able to find a definitive answer to which knock sensor is #1 and which is #2. Getting a PO325(#1) and want to make sure I get the right one. Can't seem to find any new ones available. I have another used one but think there is no way to test them. Any ideas?
E1
Crash Tested
Chicago area
In you electric print if you have one.
It SHOuld disciminate between sensors with either a wire color or number. i.e - 0325 is a pink wire, where 0326 is a white wire with red stripes, etc.
NoSlo
SHO Owner
Portland, OR
Also, knock sensor 1 is PCM pin 57, knock sensor 2 is pin 32. Signal return from both is pin 91.
Knock sensor 1 has yellow wire with red stripe, and is at the end of the harness: knock sensor harness.
Resistance of the sensor should measure between 4.39 and 5.35 megaohms.
GEN 3 SHO FAN
Canada
Ok... These knock sensor are uniques to the V8 and Duratech 3.0L engine only for the years 1996 to 1999... They could be hard to find.
Someone knows the part number for them ?
