The entry keypad on the driver's door pillar will start flashing for no reason when it is parked. This causes the battery to die after a couple days. I've done all of the things like disconnecting the battery for a few minutes, looked for any fuses that I could pull, hooked up a diagnostic tool, and finally took it to a Ford dealer...nothing has worked...can you guys help...PLEASE...I have a 2010 SHO that works fine...the problem is on her 2016 Taurus Limited
Thanking you in advance,
Bosshogg
Bosshogg
