Dylan
I've got a problem with my 98. I went to try and start it. It's been sitting for a few months. And when I put the key in to turn it, it doesn't move. It's in a locked position. It will giggle a TINY bit, but that's it. And the steering wheel is locked also. But that too will move a tiny bit, but that's it. I've tired for a bout half hour, tring to turn the key with the steering wheel in different spots (from lock to lock, which is only about an inch both ways).
I did try to take out the key cylinder but, since the key wont turn, the cylinder wont unlock. And I also tried to start the car by removing the ignition box (moduel) and pushing the peg on it to start. It did get the fuel pump to come on but once in start mode, it shut off. I'm assuming it's the PATS thinking someone is trying to steal the car, so it wont start.
Does anybody hane any ideas on what I can do to get the key to turn?
I can easily take the coulmn out, cause EVERYTHING in my car is removed, due to some weight reduction plans, and bring it too a ford dealer. If they can take the key cylinder out and put a new one in and give me a new key, or if they can unlock it.
Thanx for any ideas or info.
