Ive been having issues blowing out spark. I had it tuned perfect at 10 psi, with a solid 12 afr and autolite 3923 gapped at .035
Friday night I turned it up to 13 and it started misfiring once the boost rises over 10. Im not sure if I need colder plugs or if the coils arent strong enough. I was running this setup with no issue at the track a couple months ago. Im not sure wether this is due to using COP or what. Its certainly annoying.
My first post in 2 years!!
Now that we have went around the mountain about the COPs.... Sho Amo, when you say "turned it up to 13" are you referring to the AFR?
Yes, boost. My AFRs are in the mid 11 range. Im trying out the parallel harness sunday night and if all goes well, the plug gap will stay at .035
However if it doesn't help i'll be lowering them into the .015-.025 range for the convention and ordering the KB boost a spark when I get home.
Gapped to .025 and running 13psi. Thanks John.
I am still going to look into the parallel configuration and the boost a spark. Website says you can run up to 30 psi with .1 plug gap.
