Just talked to eibach, no plans on a kit? wtf
beefcake
cincinnati, ohio
are you kidding me, someone needs to get on the drawing board with this $hit,
i got money to spend lol
i need some cross drilled / slotted rotors, lowering kit, a nice louvered hood would be okay
jeez,
roland
Volvo fanatic
Chengdu
you could spend that money on my 99!
how about some 6 pots up front, they'd look nice with some 15 inch rotors behind those front wheels!
typhoon5000
Ferd Enganear
Shelby, MI
You might be able to use the rotors that fit on new Mustangs. It shares the same bolt pattern and hub dia, so they might work. They would need to be mocked up first of course. If the bolt spacing for the caliper is the same as the Mustang, you might be able to swap calipers too.
I know Brembo did at least a cost purposal for 2010 SHO brakes, but it would've costed $5k to the customer so Ford scrapped the plan. You could see if they plan on making that purposal for the aftermarket. You could always get your rotors machined to be slotted or cross drilled too, but I don't think you would gain anything from that since your swept area would actually decrease without an increase in diameter.
Aspect
Lowell, Michigan
Wish List:
thicker sway bars
tubular control arms
15" ceramic brakes (ala Corvette ZR-1 / Ferrari Enzo) with 6 piston calipers
Tein Coil Overs with Bilstein Adjustables
Nitto 555r all alround
Carbon Fiber hood and truck lid for some weight reduction
Rear difusser for better aerodynamics
Upgraded Turbos with a full FMIC
Build forged motor capable of 30+ PSI
Active Center Differential
RonPorter
SHO Club of America
Lake Orion, MI
jeez,
Get with these guys:
http://www.eatonsprings.com/
If they don't already have the specs for the stock springs, you could get them, and they could make up about any spring rate and/or height you want.
todd03blown
GA
that would be nice is the GT500 brake setup would fit on the front of the '10 SHO.
pwrshft99
il
Maybe Air Ride Technologys will come out with a kit.
On a luxury/performance sedan it could be a great choice. Adjustable ride height with no loss in comfort always sounded good to me.
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
CALIPER. Not Caliber.
Just hang on for a little bit. I'm sure Eibach will have springs by the end of the year. If not, custom springs are a great idea. Just from experience, D/S rotors are not so good. They look cool... Just give this platform a few months.
If you build it, they will come.
shobote
Naperville, IL
Well, there has also never been an engineered suspension kit for any Taurus. Lowering Springs alone is not a suspension upgrade as it all needs to be dialed in as a package with the appropriate shock valving, bushings, anti lift / anti dive kit, etc.
Delphi's Magnaride, would be a nice package http://delphi.com/shared/pdf/ppd/chsteer/magneride.pdf and you don't have the harsh ride problems on rougher surfaces.
typhoon5000
Ferd Enganear
Shelby, MI
never tried a custom spring, a lil scary lol
This is what all of the Crown Vic/Grand Marquis guys do, since no on makes a kit for that either, unless you have rear air ride, because Eibach makes a front spring kit and then you just adjust the height of the air ride to compensate. Since coilspsrings.com has alread donr a bunch of CV's they know the spec, but it would be abit more difficult with an unkown to begin with. The CV guys haven't had any problems with their springs though.
RonPorter
SHO Club of America
Lake Orion, MI
Most of the street rod guys, as well as track folks, do it all the time. Eaton makes a lot of OEM springs, which is why they have a lot of blueprints for factory setups. If they have that, you could specify what load rating and height you want. If not, you could get the specs for the factory springs and discuss with them what it would take to get what you want.
Similar to what Vadim did with the linear springs, but he had QC problems with whatever vendor he selected to make them. Personally, I would rather have linear springs than the progressive setup that Eibach has. Better for track use. That's what I've got on the LGT coilovers.
ViPER1313
Ijamsville, MD
no, ok, no, please :)
I really love all the tweaking you are doing to your 2010, but I will lose all respect for you if you but a ricer hood and crack prone rotors on your car.
Keep up the good work :omgsho:
HappyGoneMad
Clawson, MI
...I agree, the car is probably still too new.
Once the car is a year or two old & has more of a following I would think Eibach of all companies would definitely make some springs for this application.
They may never make a whole "kit" for it though...in which case you'd have to wait for other companies to come out with shocks, swaybars, etc. and then just pair them up with your Eibach's.
If not, I'm sure other companies will come out with springs, shocks, coilovers & other suspension upgrades. Just give it time!
jedhead
westminster,ca
I have SHO Shop Linears on my SHO. I like them better than eibach and intrax springs. Downside is that the linears really drop the car 2.5" in the front and 1.5" in the rear. I have TCE adjustable arms so aligning the rear was easy the fronts were a little more difficult. My halfshafts wear quicker too since the car is lowered and they run at a slight angle all the time.
The new 2010 owners can get a committed number of people with downpayments upfront you may be able to convice one of the manufacturers make a run of springs.
Bob
pwrshft99
il
Thanx man !! Yellow was a tough choice but no regrets. Sadly its been parked for two years, last year I played with a Lightning and this summer was getting ready for my son.
The real sad thing is my SHO has been parked right next to it the last 3 months since I bought it.
First it was all new brakes, now its a trans or vss issue.
If it wasn't for my Saturn id be screwed !
