Uh oh... time for some turbo math!!! WOOT
All calculations are at sea level and 80*
10 psi + 14.7 = 24.7 / 14.7 = 1.68
Pressure ratio: 1.68
3.0 liters x 61.02 = 183 CID
Max RPM: 7500
Volumetric efficiency: I'll assume 90%
So...
183 x 7500 x .05 (4 stroke takes air 1/2 the time) x .90 / 1728 (inches into feet) = 357 CFM
Now the CFM under boost will be: 357 x 1.68 = 600 CFM
600 CFM x 0.074 (weight of one cubic foot of air at sea level and 80*)= 44 lbs/min
And we'll also assume that full boost will be reached by 1/2 max RPM which is around 3800 (22 lbs/min)
Here is the T04e 57 trim:
Way too small. The line runs right off the map around 38 lbs/min.
T04b S:
Again, way too small, this map only goes to 38 lbs/min.
t04 60-1:
This pic is a little screwed up for some reason, but you can still see that this is a great turbo. The lines runs right though the middle of the efficiency island and just starts to fall off at 44 lbs/min.
The T-61, T-64, and T-66 could be used too, but they would be better suited to high boost... If I were you, I would definetely go with the 60-1. Besides, Toolman said it's a good one, so what else do you need?
*edit* BTW it's $649 here:
http://www.turbocalculator.com/map-t04.php?img=t04-60-1&turbo=Garrett T04 60-1
