jumpy/stuck tach
ryein7
KS
ok i have heard this is a common problem however i want to figure this thing out for sure. it is a 91 SHO and at idle the tach usually reads about 1000 rpms too high and when driving around it can be very jumpy. however the jumpy tach doesnt effect the engine at all it still drives just fine it is just kinda frustrating to look at. is there an easy fix or a definate fix for this?
TYSHO
Earth
My 89 did that until I replaced the guage behind the cluster. I don't know if 91's can do the same thing or require the whole cluster to be swapped.
ryein7
KS
so my best bet would be to grab a different cluster from a junk yard? what years are Compatible
TYSHO
Earth
89
90-91
92-95
If you need a 92-95, I have an extra one I was about to throw away.
