Jaguar brakes
It was a Ford product. Was it modeled on the Contour? Not sure if those are interchangeable with the SHO brakes as a direct bolt on. Interesting.
gamefanatic
Barstow, CA
Bolt pattern aside the real issue is the alignment of the brakes. The calipers will fit as they are the same. Some have used washers or official spacers, otherwise a modified bracket. If you can get the calipers cheap off the model car, that works in favor. Many GM's, Cadillac and others will have Baer, Brembo or Wilwood depending on year.
The only thing after getting them mounted is making sure the hoses fit up...
I personally am just going with the Cobra's for now and modified Mustang 13" rotors. Just need to get the cables probably this summer.
