NotSoSlowSHO
Gas is $$ WALK!
After 8 years of owning this '89 SHO, Im finally getting the AC working. It has never worked since Ive owned it.
As far as I know it was never changed over to R134.
I started by replacing the schrader valve stem cores. The one on the Low side had an obvious leak. The small o-ring was toast.
So the system has been "open" to atmosphere for a LONG time.
Thinking I might get lucky, I picked up a generic R134 Retrofit kit, that included a can mounted gauge.
With the system being 100% empty of any charge, I had to use a jumper wire on the the pressure switch to activate the compressor and allow it to take a charge.
2 cans later (28oz) I have 60 degree air coming out the vents, in 85 degree ambient.
But I think the compressor is cycling too fast. Engage and disengage of the clutch every 6-8 seconds.
Is this too fast? If so, what do you think is the problem? And better yet, how do I fix it?
I know this is far from the "proper" way to do this retrofit, but I really dont want to spend much money on this.
I really just want an AC that works, and doesnt blow up.
Im perfectly happy wit 60-65 degree temps out the vents.
Thanks for any help.:wave:
