sperold
Last to Know
My 90 SHO was on a hoist, and when lowered and driven, had a buzzing - rubbing noise coming from the front.
Turns out my front coil spring had a break in the bottom coil, about half way into the first turn. Just happened to be over the unsupported part of the spring bottom cup. This happens to be right where the tire just misses the strut / coil assembly. It had been broke a long time as it was rusty.
Being on the hoist, allowed the remaining spring coil to move out into the path of the tire, and that was the rubbing / buzzing noise.
I took a cut-off wheel and nipped the offending coil part off, so that it can be moved around.
When I looked on the other side, the spring was broke in the exact same spot, so I am thinking this is something to watch for on the 89 to 95 SHOs.
It would have been a real problem if it would of happened in the middle of a road trip.
