It is not coolant! It is ........
91SHO
Lima Ohio
GAS!! I decided to pulloff my intake today and see if I could see anything that I could have missed. As soon as I pulled the TB off I could smell it and see it lined my entire intake. What did I do wrong? How is gas getting into my intake?? Do you guys think that it could be a timing issue, or I don't know.. I am at a loss. I still am not getting as good of gas mileage as before even after I changed the o2 sensors. Do you think that one or more of the fuel injectors are staying on? What controls this, just the computer? If so then is itthe computer or the injector, or better yet why don't I take your suggestions and we will go from there!!
Thanks ahead of time.
Did you mess with the fuel rail while the intake was off? My guess is fpr related. Is it wet over there?
91SHO
Lima Ohio
no, I didn't touch any of that. All I did was remove the intake, clean it, and put it back on. I also replaced valve cover gaskets, spark plugs, the battery, and the o2 sensors.
tinkerkathleen
