issue with this code
ThatShoGuy
michigan
well i have never really fix anything this code but it keeps reappearing every few months i never fixed anything with it but it has happen 2 or so times..
code will appear and then like a month later its gone. 3months later it came back and so on till today.
what cause's this code i know what the code stands for.
P0412 SAI System Switching Valve A Circuit Malfunction
now i just need to figure out were or what it is?
thanks
The SAI has a vacuum actuated valve to turn it on and off. This is controlled by an electric solenoid valve. It would have to be the electric one that is malfunctioning. Both are attached to the surge tank on the drivers side.
ThatShoGuy
michigan
is it on that same bracket the dffe thing is on?
thanks again paul!
No it is to the right of that bracket on the very end of the surge tank. The water hoses are attached to it too IIRC
ThatShoGuy
michigan
6 is the only valve. The rest is pipes and fittings.
i kind of didn't realize that but i didn't know if you were also trying to say it was located in that pic but not numbered .. hmm owell thanks again
im bout to change the alt out again since it is completely dead!
