Is there anything else I should do while I have it apart?
jelloslug
Digital
Greenville, SC
I am about to install my adjustable rear control arms, I am also installing an H-brace, and TPR bushings from the groop buy. My struts, brake pads, slider, brackets, and calipers all were replaced about 8k miles ago and since it's a '90 I already have the larger sway bar. Is there anything eles I shoud do while I have the rear suspension apart?
89 Gary
Millbury, Ma.
I would and did-replace all the bolts/nuts which keep those arms together. Make sure to **** them all up with a good synthetic grease.
jelloslug
Digital
Greenville, SC
I have the bolt kit for the control arms (they are the GTP control arms) I will probably replace any other bolts that I can also, The TPR bushing kit has TPR sway bar bushings, and strut rod bushings, so I have that covered. Thanks for the ideas, keep em coming. :)
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
jelloslug:
Sounds like you got it covered. Or Maybe you could get you a set of those knuckle braces. I remeber they had a group buy on them a while back.... I was wanting to get some, just didn't have the money then.. wink
poffffd
