Is There a Book that Helps With Codes and Problems
EddieO
Louisville,KY
I have the codes from my car. Now I need to know what to do next. Anyone know of a book that will help relate problems that causes codes.
Eddie
S
slosho
Guest
www.shotimes.com
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a "PCV" line
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
More specifically: http://www.shotimes.com/SHO3eeccodes.html
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
EddieO
Louisville,KY
Well, I have the codes from shotimes, I need to know what parts I need to replace, to make these codes go away.
I talked to a person at Autozone. He said I could bring the codes in, and he will give me a print out from their computer, on what parts I need to replace.
I just didn't know if they had a book that would do the same thing.
Thanks, Eddie
fredhurderjr
www.neshospecialists.com
I wish it was that simple.
Seriously, for example, if you have a Lean code, it is likely the O2 sensor, but there are other things that can cause that. There is no perfect cross reference between codes & parts - if there was, I'd have bought it a LONG time ago! Good luck & let us know how you make out at the store.
