Is heat wrap necessary?
kenneth mccoy
Prattville AL
I just bought catted downpipes and was wondering if heat was necessary since the pipes are bigger and may sit closer to PTU and other components.
SaveMelMac
Texas
When I get DP’s I’m going to wrap them. If you can do it, I would.
If you live in a climate where your don't get a lot of moisture, then yes I would wrap them. If you live where you get of water, I would get them coated.
yaycandy
Aerospace Engineer
Hanover, PA
Usually heat wrapping headers makes them only last a few years. Not sure how it would act on our downpipes. Fatigue in metal is real, i deal with it in aerospace on much better materials. Livernois downpipes are cheap stainless material, im sure ppe are too
Ecoboost_xsport
Sacramento, CA
I'm not a fan of heat wrapping. Yes, it does work, but will destroy your pipes over time. Done it a bunch of times on motorcycle pipes and it just kills the pipes after a few years, everytime. It holds moisture and wreaks havoc on the metal. Even stainless pipes aren't immune. Most reputable aftermarket downpipes are made of 304 stainless and even that will oxidize eventually. But what's worse are the welds, the welds are what typically go first.
I would ceramic coat them. Or if your really adventurous, have some downpipes made of 321 stainless. Even more corrosion resistant and holds in heat like ceramic coating does. It's pricey though...
But to your actual question? I would say a better question is:
Is heat management necessary (with regards to exhaust)?
Absolutely it is...
Ecoboost_xsport
Sacramento, CA
Do any of you know anyone who has used VHT flameproof on any exhaust part?
Anything you spray on with a can will not last. It'll flake off probably within 6 months.
Just pony up for the ceramic coating. Doin it right the first time will pay dividends in the long run.
