hi im working on a 93 sho right now i just fixe the steering wheel shudder by turning the rotors
and now im moving on to an intermitent stalling problem
the engine speed will drop to 500Rpm and rise back to idle for about 20-40 seconds and then will stall then you start it back up right away and sometimes it does it sometimes it doesnt
if you leave it in gear (automatic) then it usually stalls but if it is in nuetral then the car does not always stall
i read somewhere it might be the cps it might be the maf sensor it might be the vehichle speed sensor i dont like throwing parts at things i am also getting trouble code number 176 which states that oxygen sensor bank two is running lean
are these two things tied in? possibly the maf sensor is giving false readings?
any help would be greatly apreciated
