Interior Lights Problem
F
fast93sho
Guest
The lights in my interior that go on when the headlights are on do not work (ex. Instrument cluster, EATC, factory radio buttons). I checked the fuse for it seemed to be fine but to be on the safe side I replaced it anyway. The window switch lights and the passenger side floor light work though. Does anyone know what else could be wrong? Any help would be appreciated.
dpsutphin
Fort Worth Texas
Had the same problem in my 90 SHO. Turned out to be a short in the wheel switch that sets the interior light brightness. Don't know if a '93 has that, but there should be some version of it that is a possible cause.
F
fast93sho
Guest
That's what the problem ended up being. Thanks a lot for the help!
ohfosho
ontario SHOwner
ontario, canada
in my 93's manual it says that there are like 3 different fuses that have a part with the gauge cluster and other lighting...check again.
