intake manifold
shonutt
Yeah I Got Rice
Saginaw MICHIGAN
i have been looking for a new intake ..the junkyard says their is a right and a left intake witch is witch and are the snakes called somthing else to ? please help
LeddZepp8687
The Keg Rider
Naperville, IL
I dont know what the technical term for the snakes are.. However, as far as I know the only way to tell left from right is to set them on the heads and make sure the bolt holes line up.
On a side note..How does one know which secondaries go where...I know they are labled L and R, but which is which?? Is the one labled R the one in the front near the front of the car?
greg geraci
Huntington Beach
The book refers to the cross over tube which the dis is mounted to, and the 2 plenums as the upper intake manifold. The 6 tubes in the center are called the intake runners, or as some refer to as the snakes.
SASHO91
Zoom Zoom
San Antonio,TX
the snakes can be reversed....
as for the secondaires... they might be able to be swithced... but im not too sure...
naval-avi8or
Chesapeake, VA
Left = Front & Right = Rear. All aspects of off the motor ar as you stand in behind of the motor looking at it. The front of the motor is the passanger side.
Dan Werling
Guest
Orlando, Florida
Correct me if I am wrong, but the front of the motor is the Left bank and the rear is the right bank...
I know that when you order parts for a car, you always refer to the car as if you were sitting in the drivers seat.
And since the transmission is attached to the motor on the driver side of the engine, that would make that the rear of the motor.
naval-avi8or
Chesapeake, VA
You are correct. I had read the opposite. I researched it again and found it to be wrong. Kinda like the spark plug wiring diagram in the Chilton.
greg geraci
Huntington Beach
Chilton spark plug diagram Bunk.
Oh man,
I'm not believing what I just read. Do you know how much trouble that chilton spark plug firing order had caused me. Complete **** and all of the brand new excitement lost in firing up my rebuild for the first time. I don't know how i figured it out finnaly because it was so long ago. But This is the first time some one else has mentioned it. I tried every thing under the sun to try to get it from back firing and what not. A matter of fact I looked at it the manual the other day and threw my arms up. although I only have 5000 miles on it since 3 years ago, I never had to deal with plugs so it was out of sight out of mind. Any ways, thanks for the confirmation
g
JoesSHO
Reality
I think some get crossed up with the description of orientation- yes you refer to the right/left as sitting in the car, but the motor is installed sideways, so just another level of confusion for the 2 hour veteran at AutoZone.
RAYJAY
WHO ME ?
UNION DALE PA
both secondaries are the same just the vac cyl. are left and right :thumb:
bikewrench
WV
What's the story on the Chiltons manual? I have #26700 that I've been using. What is the correct firing order?
yamahaSHO
E85 whore
Arkansas
Are you looking for the firing order, or the order the wires go in?
I believe you want the latter...
Engine:
1-2-3
4-5-6
coil pack
5-1
6-2
4-3
LeddZepp8687
The Keg Rider
Naperville, IL
Engine:
1-2-3
4-5-6
coil pack
5-1
6-2
4-3
Thats correct..
Just gotta rember that "gotcha" on the coil pack with plugs 5 & 6
naval-avi8or
Chesapeake, VA
Correct Diagram
Engine
1 2 3
4 5 6
Coil
5 1
6 2
4 3
INCORRECT CHILTON DIAGRAM (8251) 26700 Published 1995 Pge 2-6
Engine
1 2 3
4 5 6
Coil
4 3:nut:
6 2:nut:
5 1:nut:
However on page 2-14 they do have the order correct on the coil pack diagram.
F-22 Raptor SHO
7015 feet above Sea Level
Hilarious.
Oh and I like the officer Ugh avitar. I have kids who know who that is.
Eliw
Brooklyn NY
Well, since this thread is about the intake, you can wait a few months and you should be able to get an intake off of the new Ford Futura Sprint GT/A Wagon. Its got the same looking (not sure if its exact) intake as the SHO with the visual exception that it doesnt have SHO ingraved in it, its got GT/A on it.
Want a peek? Take a look at the June 06 issue of Car and driver
yamahaSHO
E85 whore
Arkansas
Yeah, you could do that, or you could save HUNDREDS less and buy it used. I'm guessing that intake costs $1k or so new.
naval-avi8or
Chesapeake, VA
Got a little off topic.
Check ebay, there are a couple up for auction weekly. If I remember correctly they have been going for under $75.
