intake gasket replacement
tavius
arizona
i am going to be cleaning out my lower intake and installing a new gasket; is there any adhesive i need to use? I am also going to clean out my throttle body and change the gasket. Will i need to use any adhesive for this? If so which should i get?
Mr Anonymous
Tire Wall
No adhesive at all, just make sure all the mating surfaces are clean.
No need to replace the TB gasket unless you disassemble it, which isn't necessary just to clean it.
tavius
arizona
ok thanks
