Intake and exhaust
MarineGuysSHO
Just bought Corsa sport exhaust cat back system and AirAid intake planning on installing it as soon as it comes in. Do I need to get my car tuned?
MarineGuysSHO
Thanks brother I appreciate it. What kind of a power return can i get from intake, exhaust and tune?
2012korn
Well the intake only makes noise. And you didn't buy downpipes which is where the biggest gains in the exhaust are found. But I would expect with a tune from unleashed or lms along with a 3bar map. You'll be in the 360whp range. Like most people.
ridered74
anyone know a good tune shop in nyc?
Go with either Livernois or Unleashed. They have done hundreds if not thousands of cars, any local shop probably has done a handful of SHO's. They will send you a tuner, then you connect it to your laptop and download the tune to the tuner, then hook it up to your car and load it. Easy as heck, and will get you a better tune than any local shop. I have Livernois, the difference after loading the tune was crazy, shaved almost a full second off the 0-60 time. If you are somehow able to drive the car like a normal adult after you load the tune, your mileage will not change. If anything it probably goes up a little bit after the tune.
Livernois Motorsports
SHOForumSponsor
Sponsoring Vendor
Dearborn Heights, MI
Hey DevilDog! We actually do not need you to goto any dyno shop. We can supply you with the best, most powerful and most reliable tuning available all from your computer desk!
Our proprietary tuning software combined with our MyCalibrator tuner feature:
Gains of over 59hp and 88tq on your otherwise stock vehicle
Custom tuning via Livernois Motorsports
Increased horsepower & torque
Dyno proven air/fuel adjustments
Transmission modifications with reduced torque management and modified shift points/firmness
Enhanced throttle response
Available for multiple fuel octane levels
Removed top speed limiter
Read/Clear (DTC) Codes
You can find the tuner on our site here:
https://www.livernoismotorsports.com/product/LPP631104
Also check out our YouTube channel:
https://www.youtube.com/user/LivernoisMotorsports/videos
You can also search through my posts here!
If you have any other questions feel free to drop me a line!
Thanks,
Jaimie Tejeda
[email protected]
2500 S Gulley
Dearborn Heights, MI 48125
313 561 5500 ext.102
Livernois Motorsports & Engineering, LLC
Fax: 313-730-7500
MarineGuysSHO
My AirAid cold air intake system and Corsa cat back exhaust got installed yesterday. She sounds amazing now I'm looking to do another upgrade. Should I go with down pipes or 3bar map and tune?
2012korn
^you need a tune to run downpipes anyway...... 3bar and tune first.
A tune is not needed for downpipes, but it sure helps to have one. A tune is not needed for a Tstat either, but rather it is the tune that says a TStat is a musthave.
But with a 3bar, a tune is a MUST. As 2012korn stated, do the 3bar & tune first. Then when you add downpipes, get your tune revised.
2012korn
Catless downpipes most certainly do require a tune.......the catted ones? Yeah maybe you'll be fine. But you will most likely throw a cel. High-flow cats like to do that.
SHOForumSponsor
Sponsoring Vendor
If you are utilizing our custom tuning we recommend having us revise your tuning for any and all parts that have been mentioned. We do not charge for any type of remote tune revising at all...EVER!
bmytych
