Instrument Cluster Replacement.
Tecchie
Marysville, Washington
For reference I own a 1995 ATX
Okay, so, I know it's a small issue but it irritates me to no end..
My original panels trip meter when reaches 9/10ths of a mile, it'll click and click and click and SOMETIMES turn over until the next mile and do it again..
Overall mileage works, but Trip meter doesn't..
I did pull a 93 instrument panel from an ATX (they look the same inside and out as far as the panel goes) and was wondering if it would work..
BUT I have a few questions...
1, is there an "easy" way to forward from 143k to my 208k on the mileage without putting a drill bit in the end and spinning it to 140 for hours on end?
2, anyone got the schematic wiring diagram for the panel so I can install LED lights? (I have some LED's already, 12v ones with varying brightness levels and colors) like a pinout? Something that I can apply a 12v source to, to get them to light?
3, shoulda put this first but are the panels completely compatable between 93/95? I know the mechanical stuff all is...
Thanks guys for all the help.. BTW, ShoSource R0CKS!!!!! You guys RULE!:thankyou:
jmpSHO
Massachusetts
The 93 cluster will fit the 95. As for the miles I wouldn't worry too much about it, just keep track of the mileage. Mine has about 280k but the mileage only reads 116k. I swapped the cluster a few months ago. By the way keep dealing with SHO Source and you will realize they don't rule after all.
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I am betting we have a cluster with somewhere close to 200k on the odometer if you need it.
Mike
