installing throw out bearing
sho4life
midwest
I just bought the sho source ceramic tob and there is a metal insert that doesnt seem to slide over the tranny shaft. am i supposed to use it? no instructions on how to install. also what should i use for pins? might be a dumb question but i never done this procedure before.
shotime1994
AirHammerAndrew
New York
Are you talking about the metal sleeve? Is there already one on the input shaft? The t.ob. kit from shosource comes with the pin.
sho4life
midwest
yes, the metal sleeve, my shaft doesnt already have one on it.. do i pound it on? also i double check but there is no pin, can i just use cotter pins or what?
shotime1994
AirHammerAndrew
New York
The pin is just to keep the t.o.b centered for install. The sleeve should be tight and should go on without extreme force.
sho4life
midwest
so i should just pound on the sleeve and slide the bearing over it and thats it?
sho4life
midwest
ok did that, is there anything else i need to do after sliding on the tob?
shotime1994
AirHammerAndrew
New York
Put the pin that should be taped to the bottom of the box in place and install the trans.
AREA 91
PA SHO SHOP
Area 91
You must coat the inside of the quill sleeve with green loctite to prevent it from coming loose.
platoribs
Live to Drive
Plat0ribs House of SHO,il
Put a deep socket on the sleeve and tap it on with a rubber mallet.
Now tear off the quill sleave (probably distroying it) buy another, buy green loctite, apply loctite and install the sleave again.
If you don't do this you'll be back in there within 5000 miles, ask me how I know!
AREA 91
PA SHO SHOP
Area 91
You might be able to get the green loctite to "wick" into the quill sleeve after it's installed. Position the tranny so the input shaft is pointing towards the sky. Now apply a drop at a time between the quill sleeve and the aluminum input shaft. Watch to see if it is being absorbed into the quill. If this works, keep slowly repeating this process until you see the green loctite run out the bottom of the quill.
:salute:
itwonder
VA
Most SHO specialists recommend installing with green Loctite sleeve retainer, and I installed mine that way. However, my previous clutch was dealer installed with no green Loctite, and there was no problem with the sleeve slipping after over 100K miles on that clutch. I have seen two sleeve designs. One is a plain sleeve. With that type, I would insist on using green Loctite. But the more pervasive kind is a sleeve that has two locking tangs cut into it near the end. That type, IMO, is unlikely to come off. If the sleeve tries to move, the tangs dig in. That is the kind of sleeve that was dealer installed on my car, and as I said it was never a problem. If you have that kind of sleeve, my advice would be to leave it on there and move on. Obviously, opinions will vary.
Let me add that the clutch installation video from shonutperformance is worth every penny and covers questions like this one very well.
sho4life
midwest
ok, im thinking the ones that came loose before the quill sleeve had excessive wear. i pounded good and hard and i dont think it will come loose. as for installing everything else correctly this is where I am. Trans is bolted up and it seems you have to put a whole **** of alot of pressure on the clutch lever and nothing happens. is the clutch disc supposed to be pressed super tight againt the pressure plate and flywheel after tighntning? dont think im missing anything else but maybe some advice on kind of fluid and how much it takes. cant find my chiltons..
zak
east of Hartford
Sure you have the disc in the right direction (one side is stamped "engine" or some such).
You will not be able to operate the clutch release lever by hand, in any event.
Racer X
SHO Pilot, Retired
Connecticut
I had to beat my sleeve like it owed me money to get all the way on.
I only used red loctite.
