Installing BBB's & Intake
Shopower400
Atlas
Electric City, NY
I have a couple of questions regarding the above...
1) When installing the BBB's there are 'metal tubes' that go into the runners, before you put the BBB's on. Do you need them or can I press on without them? If so what is to be gained or lost from having them or not???
2) Once that is complete, what is the best way to put the intake back together & get it on the car? I was thinking to bolt on the snakes, and then assemble the runners / BBB's around them. Does that sound like a good idea or no? What have others done?
I just don't want to scratch up the paint, and more importantly I want to make sure there are NO leaks!
Thanks, Sal:salute:
NovaSS
Project MINIGUN
most everybody leaves them out
put the snakes together, intertwined, Then paint them and never take them apart.
yamahaSHO
E85 whore
Arkansas
Are you guys doing it this way??? You can easily put the back together without scratching them..
hawkeye18
Sorta cares
Norfolk, VA
What a lot of people do is assemble the intake with the intake hose clamps loosened. Put the whole intake on the heads and wiggle as necessary to tighten the bolts down... then tighten the hose clamps. Voila!
And the horns become a huge restriction to BBBs, thus completely negating the point of installing them.
Remove them.
AREA 91
PA SHO SHOP
Area 91
Thanks, Sal:salute:
#1 Do not use the velocity stacks.
#2 Assemble the snakes first, then the plenum's. Now you can put the intake on the car. Make sure the intake seats flush on the head ports.
Now you can tighten the runner bolts. Tighten the hose clamps last.
Isn't it nice to have someone actually answer your question.;)
Shopower400
Atlas
Electric City, NY
Hey Area 91, just curious, what does your "91 lightly modded" have done to it? I noticed you ran a 14.5 with it... I'm also guessing you're a pretty good driver?!...
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
X's 2... OR you can assemble the entire intake manifold first but just leave the clamps a bit loose, just loose enough for the snakes to "wiggle" so that they sit flush on the heads. Then tighten all 12 bolts & then the clamps.
AREA 91
PA SHO SHOP
Area 91
3.2 swap
udp
cai
y pipe
cat back
gasket match
Bone stock intake!
