installing all new stereo components tomorrow
camzaro28
fargo
putting in all new door speakers, rear panel speakers, and a head unit.
my car has the amps in the trunk, how do i go about bypassing them? and once i do that, do i have to rewire all the speakers straight to the headunit?
anything else i should know? any secrets to takin panels off? anything of the sort?
TIA
brian
p.s. i havent installed any stereo equipment in over 6 years, so this is gonna be fun.
SlowHeavyObject
philly
easiest thing to do is get some harness kits. you should buy something called an "amp bypass" harness kit as that is the simplest to hook up. also get some speaker harnesses too. that way you can put eveything back to stock in case you wanna sell the car or god forbid it gets in an accident.
there is a tiny trick to getting the front door panels off. since the panels have a lip and are not flat like older cars, when you pry them off start at the top first and after all the fasteners are out you have to lift it off on a diagonal to clear a mount.
traxster
Guest
wisconsin
And I would put new speaker wire in. You dont have to put you will have much cleaner sound. Plus it fun to wire!!!
camzaro28
fargo
well i didnt get the amp bypass harness. all i have is the basic harness to hook it up without tearing it all apart and chasing wires.
the harness kit is part number : metra 70-1770
it does not say anything about being a amp bypass. so do i have to rewire everything if i dont use the bypass kit?
thanks again and i dont feel like running all new wires to the speakers. that is to much work. lol
camzaro28
fargo
ok got the factory deck out. now anyone know the part number for the "amp integration harness" to keep the factory amps?
i found one that peripheral makes but the guy i am getting everything through carries metra. so i need the metra part number!!
well thanks again guys, this is already ALOT of fun
