back2SHO
missing SHOs...
input, please :: did i totally screw up my tranny?
i blew the drivers' side CV joint on my '93 MTX a while back...had a spare from my '89, so i put that in...seemed just fine except for the obvious lack of ABS on that side. well, i finally got around to picking up the replacement for the '93 from car quest today and i can't get the damn thing to go into the tranny! it looks like the one that was in there would go back in ok, but i've NEVER had trouble like this getting one of these things in...i'm wondering if i jacked something up.
as far as i can tell, they did give me the right part...verified the numbers and everything and they swear its for the '93 MTX...length matches, splines seem to match...the only thing that looks odd is the one that came off the '89 is a bit more tapered on the inner shaft...probably why it goes in easier.
old part number from the inner shaft assy = E7DW AA 13528
new part number = E6DW CA 1268 1B
inner shaft design is pretty old, eh? maybe they changed it in '87 to something slightly different?
any input here would be greatly appreciated. i can put the old one back in and be mobile again, but i'm starting to get concerned that i've done some damage internally. i was feeling a vibration from the left-front, especially bad when backing up and turning...it's quite likely i did screw something up.
if i did, i'll have to swap trannys, i guess.
she's apart in the driveway right now, so if someone can chime in quick, i'd appreciate it. i'm going to go back out and see if i can't get this thing in. if pics of the splines would help, i can take them...
thanks, all.
-t.
thanks, all.
-t.
