JRA2000TL
The Complainer
I got another long bolt to replace the missing one in my front motor mount; tonight I attempted to get it back in and ran into problems.
I cannot get the holes to line up correctly for the "top most" longer bolt. I was able to get the bottom (left one if looking through the pass wheel well). No matter how much I adjust the jack raising and lowering the engine, I still cannot get the holes for the right bolt to line up. I even pulled the lower radiator hose loose to give me more room. Didn't have a decent pan handy nor did I care so I just let the damn coolant go all over the garage floor. So I'm lying in a puddle of coolant constantly adjusting the engine height with no luck. The 2 nuts to the far right for the front engine dampener are still in, as well as the large 18 or 19mm nut that connects to the subframe.
I don't think the engine dampener nuts make much of a difference, but should I loosen/remove the subframe nut to get the mount to be a little more flexible/mobile?
After being soaked in coolant and ******, I decided this was not a project for Sunday night at 8pm, so I said eff it for now. Any advice on how to get this thing to line up properly? SHOPhoenix is down, so I can't look at the write up again.
