Captain,
No apology necessary, and you're not being a pain. We are all here to learn and help one another. If you do not understand something you should ask about it. And you have. So here goes!
Yes, I was referring to the EATC self test. I believe that if the blend air door motor is not working the test will bring up a code. My thoughts were to possibly get a hint if the inoperable blend air door code is indicated.
The climate control system uses the blend air door to adjust the temperature in the cabin by allowing outside air to "blend" with the air produced by the heating (or cooling) system. This is how the temperature you select is maintained. If the blend air door is not operating and in an open position (to outside air) your heated air is getting too much cold air "blended" in with it so that you are getting luke warm or cold air in the cabin.
Also in the EATC, or climate control system, there are also vacuum "motors" that operate doors that direct the flow of air being pushed by the blower motor, e.g. the door that redirects the air from the front of the dash to the defrost vents when you push the defrost button. So, I suggested that you check the vacuum lines and vacuum motors for any that are not operating correctly.
There is a vacuum control unit in the EATC control that gets its vacuum from the engine via a line (black) that goes through the firewall at about the center of the firewall. The line iis attached to an in-line check valve near a vacuum resevoir. (black canister).
The control unit directs the vacuum to the 3 (I think) vacuum motors, 1. to the right the one that controls the outside recirculation door (white line), 2. the one in the middle that controls the right and left indtrument panel registers ( red and blue), and 3. the one that controls the defrost door (yellow).
So, if these doors all opeate properly when you "push their buttons", which would indicate that the vacuum system is OK, then we are back to the blend air door and its motor. Operate the button and listen for the doors to operate. If you do not have a vacuum pump you will have to have the engine running to get vacuum (manifold vacuum).
I may be easier to remove the glove box and a work light or flash light and visually watch the doors operate.
Keep in mind that you may not have to do any of this if the air is being directed properly, e.g. if you put on defrost and the air is directed to "defrost" then that vacuum motor is working properly. If the other doors operate properly when the botton is pushed then the vacuum system is OK.
Do some or all of what is recommended above so you know better what is or is not working properly in the EATC system. Then get back to us and we can narrow the problem down. Just for grins and giggles, if you have a parts car pull the blend air door motor and try it on the car in question! rangerj
