I have been having intermittent fuel gauge issues. Maybe someone can help.
The problem is when I start my car the gauge will be reading E and the light will be on even though I have gas.
I dont have this problem all the time. Here are the situations.
1) I replace my fuel pump and for the next fuel days there is no gas gauge reading.
2) I stop at a store to buy a dvd, come back out start car and no gas gauge reading.
3) Start my car after a full days work and no gas gauge reading.
The gauge always starts working again a day or two later. Two times it started working as I was driving. The third time was when I started the car back up the next day it was working.
I dont feel that the problem is a loose wire or connector because, EVERY time I have had this problem it works fine when I turn the car off and then isnt working when I start it back up. If it where a loose wire or connector I would think that a bump or jolt would cause the problem. But when the car is turned off there isnt any bumps or jolts.
The problem always occurs between 1/2 tank and 1/4 when it stops working.
Do any of you feel that there is a problem in the slosh module area or wireing? Or do you still suspect loose wire even after the opinion I just gave?
Thanks.
P.S. I am trying to contact the previous owner of the car to see if he ever had that problem. I am doing this because I had to replace the fuel pump 2 days after buying the car and never really used the old one. I did at that point replace the whole sending unit. If he has never had the problem, I may suspect that it is something I caused which would mean sending unit or connectors at the tank.
Thanks.
