im confuded
moobypets
mooby
quebec
confused sorry bad word
well not a good day today my car for some odd reason did not start at all and i can smell the gaz so for now im guessing no spark
so it either the module the coil or the crank sensor
im lost and need help
and it decided to do that just like that
firebat45
Edmonton
Check for spark, take a plug out and hold it against a ground when you crank.
moobypets
mooby
quebec
i called zepto and he told me start it like it was flooded and it started
im confused has ****
but it run now
so confused im happy it run
but why did it flooded itself ??
new plug wire
I have had a couple of SHOs that would randomly start hard, especially if I just shut them off hot a few minutes ago and wanted to start it up right away.
This was made worse by my occasional habit of just letting go of the key after half a second without paying attention to if it really started yet.
If you try to start it and it doesn't go on the first try, you can pretty much assume its flooded and put the pedal to the floor to get it started.
moobypets
mooby
quebec
i just completed my sho swap so i have a 90 sho in my 94 gl
i have some weird light prb (flasher and brake light )
i need help cuz my car crank has fire but no gaz plus I dont hear the pump and i dont have power to the wire plus i have a damn 5 tone beep coming near the computer like 5 time in a row and ..... and the car is not running grrrrrrrrrr
plzzzzz anybody help
and when i start the car the rpm needle dont move and stay at 0
How did you do the wiring? The SHO wiring harness is populated differently from the GL wiring harness, so you need to make those changes in the wiring.
You will need to get the wiring diagrams for both the 90 SHO and the 94 GL and then rewire the stuff that is different to make it work right.
