Ignition maintenance hierarchy...
Ferendon
Fort Worth, TX
I have:
oil in plug wells
crappy wires
crappy plugs
I need:
dry plug wells
new wires
new plugs
Should I fix the plug well issue first? And what does that take, and how long/much?
Dr. Tweak
Mad Scientist
Northern Vermont
Yes you should fix the well first, the instructions are on my website. Even if you don't do the whole upper 60k right now at least replace the valve cover gaskets and plug well seals and then get some decent wires/plugs.
projectSHO89
SHOless In St L
Ferendon:
I have:
oil in plug wells
crappy wires
crappy plugs
I need:
dry plug wells
new wires
new plugs
Personally, I would do them all at the same time.
Parts cost - around $160 - $200 depending on which plug wires you pick. Low end estimate is for AC Delco wires, Motorcraft plugs, and Felpro gasket set. Add around $40 for Motorcraft wires.
Steve
hosbaldosho
