Cward
finder of parts
Hey guys, wondering what one code is and how to attck the other three.
First-code 211 ignition PIP sinal was erratic or missing. Okay what is PIP?? Could this be a ignition switch problem or coil??
Second- code 542-fuel pump open,bad ground or always on.
code 556- fuel pump relay primary circuit fault.
code 557- low speed pump relay circuit.
Wondering if I should just try putting a relay in? Or should I be digging for a bad wire? Also is there a "low speed pump relay" and a normal fuel pump relay?
Thanks guys!
Thanks guys!
