I need more help than I can get!!!
ckinney89sho
fo SHO
NY
Well heres the deal. My sho has a problem with the automatic lights and the dash lights witch neither seem to work, I think they're connected to the same relay, maby. Am i on the rite track or should I try something else first. Also, I have a clunking noise out of the front end. I've already replace the tie rods(inner, outer), ball joints, and sway bar links. The sway bar bushings and wheel bearings arent bad. So what could it be? Ive greased everything that could get it but its still there when I turn in both directions. I dont know if it could be the struts. Thats about the only thing I havnt replaced yet. Any suggestions.:thankyou:
The most common cause of front end clunks is bad strut mounts, in my experience - the part at the top of the strut that mounts to the body.
Did you check all your fuses for your lights problem? I'm guessing that you have a blown fuse.
boat
Likes blue ones
Tallahassee, FL
Possibly the subframe mounts? Wouldn't that cause a front end clunk if one or more were loose?
ckinney89sho
fo SHO
NY
I checked the sub frame bolts and one of them is bad. I cant tighten it up because the locking nut? just spins in the body. thanks again.
If that's on the rear, then its likely that the car needs the subframe bolt recall done to it.
