ckinney89sho
fo SHO
Well heres the deal. My sho has a problem with the automatic lights and the dash lights witch neither seem to work, I think they're connected to the same relay, maby. Am i on the rite track or should I try something else first. Also, I have a clunking noise out of the front end. I've already replace the tie rods(inner, outer), ball joints, and sway bar links. The sway bar bushings and wheel bearings arent bad. So what could it be? Ive greased everything that could get it but its still there when I turn in both directions. I dont know if it could be the struts. Thats about the only thing I havnt replaced yet. Any suggestions.:thankyou:
