I need help!!
MikeMike
Ohio
alright, i posted before about a sho, i am looking to get a 97, and i am not too sure, when i popped the hood, there is a hose missing
http://shoforum.com/FeaturedSHO/Wuzzzer/enginebay.jpg
to the left of the engine, on top of a resoivor, there is a hose that is on top of it using brackets, and it goes to the back of the car, from what i saw from the picture and then goes down, on the car that i am looking at, the hose is not there and it is just empty clamps, can anyone help me on what is it and if it really is needed
wuzzzer
MN Moderator
St Cloud, Minnesota
I can't answer your question, but here's a little larger picture.
What part exactly are you talking about?
Oh, thanks for posting the pic of my engine, too. :D
MikeMike
Ohio
thanks, i know how to explain now, if your facing your car and you see the window washer fluid in the top left and it's like clear with a black cap, and then below it there is the black resiovior with a black cap and orange writing on it, there is a hose clamped down on the right side of that resiovior and the SHO i am looking at the hose is not there. hopefully that helped a little more
MikeMike
Ohio
wuzzzer
MN Moderator
St Cloud, Minnesota
Alrighty. Well, I believe what you're describing is the coolant overflow tank. If there's a hose missing, I'd say that it's definitely something to check into further.
MikeMike
Ohio
thanks, but do you have any idea on the hose i am talking about and what it is, i ran the car and it sounds great. also, i called the local ford dealer and they said they have heard of shafts that are behind the engine, the woman i talked to was not any sort of mechanic and she said there is a shaft behind the engine that rots away and breaks and to replace it you have to pull the engine. any ideas on that?
wuzzzer
MN Moderator
St Cloud, Minnesota
Sorry, that's all the farther I can help out (I know it wasn't much)
Hopefully someone else will jump in here and help out.
MikeMike
Ohio
also, the hose i am describing isn't a hose off that tank, it is a hose that is going over the top of it
Tunez
NC, USA
It does come out of that clamp just so you know and will go pretty far down beside there as well. I took mine out last night to make it a bit easier to change a head light. I would say to look down in the opening to the side. It will be the smaller one with the wire loom over it.
I would guess this is the one you mean.
<small>[ January 30, 2003, 08:03 PM: Message edited by: Tunez ]</small>
MikeMike
Ohio
exactly! thats the one that isn't in the clamps and then there is another hose that just sticks straight up with an aluminum tip about 4 inches more twards the bumber mine looks like it's broke off at the top plastic part. any idea on what that hose you pointed out and the one i am describing are???
The item pointed to in the picture with the red arrow is the alternator output wire.
Thant is the A/C fill port.
