Hey guys...I'm trying to figure out what is wrong with my SHO! Here is what happened...
1994 atx - I replaced the radiator in the car recently. Turned the car on after radiator install, and it ran just fine. My dad then gave the car some gas, and it sputtered and died. It was running fine previous to this. Now it will NOT start back up! It cranks and cranks and cranks, but will not start. The only other thing that has been replaced recently is the waterpump (by Ford, ugh).
So, here's what I've checked for.
-We have spark
-We have fuel (don't know exactly amount of pressure)
-Removed the upper timing belt cover, to make sure it was still lined up correctly. It appears to still be lined up right.
-Ran codes with my crap code sensor. "All systems pass".
-Heard that it could be a fuse problem due to the coolant sensor going bad. Checked fuses, none blown.
-Tach does move while cranking engine. (I believe no movement indicates bad CPS).
So what gives? Dad and I are BOTH at a loss on this one. We really need some help! I've owned lots of SHO's and am fairly familiar with them, but this one has stumped me!
ANY help would be appreciated!
Thanks
Joel
-We have spark
Thanks
Joel
