jthod
Mr. Goodwrench
I found this little peach in my oil pan.
http://s270.photobucket.com/albums/jj85/jthod/
This thing is going to go on the top of my cake for the week.
I just got home from picking up plastic grille pieces and glass off the gravel road from the deer that I absolutly creamed last night with my grandpa's '84 Toyota pickup that was my loaner car while the SHO was under the knife, AGAIN!!!
I pulled the car into the garage on Friday. It started doing the old rod knock in town and I babied it home, all 17 miles. I got it up on jacks and got the rod bearings ordered. Just this afternoon I pulled the pan of and found it^^^. Other that the pieces in the picture, there was just a little sludge on the bottom of the pan, and a little on the pick-up screen.
The car was still running great, it just started knocking a bit. I have not removed any of the rod caps yet. I wanted to get this up before I go to work.
. I almost thought that was a screw... that definitely looks like it was too much material to have come from a single bearing... and I've never seen a crank shaved like that. Perhaps if it was the entire length of the bearing? I'm also assuming the nut didn't come out from there too... there's a pretty straight score mark up the spiral of the shaving. Damn. This needs to go on the "this is why you need to change your rod bearings" faq... if there is one. Sorry for the loss!
