I failed my emissions inspection today...
Racer X
SHO Pilot, Retired
Connecticut
...and I have no intentions of doing major repairs to get it fixed, since I'm swapping in a new motor in the next few weeks.
The car's history:
210,900 miles
Diagnosed with crank cancer at 203,000 miles
1 possibly leaky injector
14 year old cats
Non functioning evap purge solenoid (bypassed with small orifice vacuum connection fitting)
The test limits:
HC 0.80gpm
CO 15.00gpm
NOx 2.00gpm
My Readings:
HC 0.59gpm
CO 5.21gpm
NOx 2.33gpm
Basically, I failed by a ****. :squint: It kinda sucks when you think about it, really.
Is there anything I can do to lower my NOx emissions just that little bit so I can pass?
sho'd said:
do the atx's have spout conector, probably a dumb question, but i can't find mine
Yep, it should be right there next to the EEC test connector.
Sometimes, they hang down and are hard to see until you get your hand in there.
SolidState
No Mo SHO
Toronto, Ontario, Canada
I find it is rare that an ATX doesn't pass due to NOx. However, the MTX has a really tough time up here passing emissions. I think it is to do with the fact that the ATX has EGR, and the MTX not...
sho_me92
it`s SHO time
utah
Two if my MTX`s has had EGRs and they both passed wonderfully and the one that didnt have it had a veryhard time passeing
SolidState
No Mo SHO
yep, cali SHOs have EGR.
EGR helps reduce combustion chamber temps, allowing a better, more controlled burn of the fuel. Also helps the 3.2L run lower octane fuel with better results.
Someone can correct me if I am wrong, but I believe NOx is unburnt fuel...
jedhead
westminster,ca
NOx is the byproduct of the combustion process. Nitrogen Oxide emissions are too high. Removing the SPOUT defaults the ingition timing to a static 10 degrees which reduces the NOx emissions. Your HC will go up some.
Bob
Racer X
SHO Pilot, Retired
Connecticut
How much will my HC's go up? I didn't exactly pass that test by some amazing margin...
