mechjames
94SHOATX
I've used up my conditional 3 month pass for our Aircare Emissions testing and now I'm restricted to temporary insurance permits at 26$ a day.
Originally after I bought the car, I took it through the test, and failed on Hydrocarbons only.
The readings are:
HC g/km= 0.7553 MAX 0.5000 FAIL
CO g/km= 2.1388 MAX 9.3200 PASS
NOx g/km= 1.0371 MAX 1.2400 PASS
So I proceeded to do a full tuneup, seafoam (worst seafoam i've ever done) plugs, wires, air filter, fuel filter, Pennzoil Ultra oil change, no PCV valve on this car (factory).
Someone also told me to put a litre of methyl hydrate in the tank to mask the HC's. I think it boosted my NOx's instead.
I then tried again, and it got worse.
HC g/km= 0.8558 MAX 0.5000 FAIL
CO g/km= 3.2470 MAX 9.3200 PASS
NOx g/km= 1.2483 MAX 1.2400 FAIL
Now I just realized that the previous owner was using 87 octane 10% ethanol, and that's the gas that I have been testing with. I've now got a full tank of 92 octane ethanol free. Could using the wrong gas cause different readings on a car designed for premium fuel?
The only other thing I haven't tried yet is changing the O2 sensors. With the age on them, they probably could be done and bump my readings down a bit.
If I do that, should I reset the computer again? (I did it after the tune up so that it can relearn the mixtures, then I took it for a 60km drive.) Does the EEC-IV have a drivecycle to get the leanest mixture? That could be also why I didn't pass, maybe I didn't drive it long enough.
Other thing I could think of is the Catalytic converters. There's 3 of them on this car. Not looking forward to the cost of replacing those.
I drove the car about 60km after the tune up (highway), and that equaled to about an hour of driving in rush hour stop and go traffic.
The last time for the etest I waited about 20 min. Usually it's 5-10, but I only got there towards the end of the day. They always make us idle in the lineup, so everything was nice and hot.
The car isn't showing symptoms of a plugged, inefficient or broken catalytic converter. Car takes off like a bat out of [censored] like a Taurus SHO is designed to. No smell of a rotten egg, and there is no rattling.
The readings are:
