1994 ATX SHO Inspected & lots of work done $800
Form1le
Lansdale, PA
For sale – 1994 Ford Taurus SHO Auto Opal Frost with 232,238 miles
Car is driveable and PA inspected through 8/17. A/C blows cold and gauges were replaced with white faced ones. I've provided an honest appraisal of the car below. Passed PA emissions test with flying colors. I have service records from previous owner dating back to 2008 when he repurchased the car as he was the original owner.
List of parts I’ve replaced
1. Battery
2. Timing belt
3. Timing belt idler pulley
4. Plugs, wires, and valve cover gaskets
5. Cold air intake
6. Front Suspension
a. Sway bar end links
b. Lower control arms
c. Strut rod bushings
7. Rear suspension
a. Sway bar bushings
b. Sway bar links
c. Tension/strut rod bushings
8. Catback exhaust
9. IAC valve
10. O2 sensors
11. Serpentine belt tensioner pulley bearing
12. Header panel
13. Front bumper reinforcement
14. Left side marker
15. Left fender
16. Passenger mirror
17. Left stainless steel rocker molding bracket
18. Left rear window motor
19. Powdercoated rear caliper assemblies
20. Rear parking brake cables
21. Interior antenna installed, bad power unit removed
Extras
Owner’s manual, few sets of keys, factory service manual, electrical & vacuum manual, maintenance book with notes from previous owner as well as folder full of invoices from previous owner and myself.
Future projects
Dents, scratches, and chips throughout vehicle including puncture to front bumper that could be covered by license plate.
Interior shows wear and some switches don’t work.
Few oil leaks and belt squeal.
Left rear section of rocker is rotted, but rocker molding covers the majority of it.
Heater core was bypassed, so heat does not work.
Check engine light & air bag light were coming on intermittently.
Disclaimer: I’m not a mechanic. I have provided an honest and detailed description of the car’s current condition including what I have done to the car to get it driveable, inspected, and what I know about the car. Due to the age, condition, and mileage, I’m selling the vehicle AS IS with no returns, refunds, exchanges, etc.
Form1le
Lansdale, PA
Bump for updated mileage and cold air intake installed
