quagmires_sho
is there a way to stick the secondaries open? and if there was, what would happen? i reckon itd lose low end power?
i might try it... once its firing on all 6 cyl lolIt will lose more power than you will like. Low end torque is iffy enough.
There is a vacuum line that closes the secondaries after start up until 4k rpms. You can disconnect the hose at the intake, plug the hole with something easy to take out and see if you like it. IIRC mileage goes way down as does low end torque. Try it and report back.
Ive tried it, you feel like it loses alot of torque because it prioritizes the short runner to the long runner and you lose intake volume. Naturally aspirated needs more intake manifold volume before the valves to add low end torque. Thats why carburetor spacers are made and high rise intake manifolds. All adding volume. Not much for hp as it is torque value.i might try it... once its firing on all 6 cyl lol
Yeah, that's kind of a priority. You cant' do much without a clean running baselinei might try it... once its firing on all 6 cyl lol
since intake volume is so important, is there ANYWHERE i can get a custom intake manifold? ik the 1000hp blue turd guy has a crazy one but i def feel like going thay far would lose high end torqueIve tried it, you feel like it loses alot of torque because it prioritizes the short runner to the long runner and you lose intake volume. Naturally aspirated needs more intake manifold volume before the valves to add low end torque. Thats why carburetor spacers are made and high rise intake manifolds. All adding volume. Not much for hp as it is torque value.
Hp sells cars
Torque wins races
true trueYeah, that's kind of a priority. You cant' do much without a clean running baseline
No. Its an engine the world forgot about, you cant even get some bearings for it. As niche as it gets. Want a custom intake made? Design one and find a company to make itsince intake volume is so important, is there ANYWHERE i can get a custom intake manifold? ik the 1000hp blue turd guy has a crazy one but i def feel like going thay far would lose high end torque
that real ig ill start savingNo. Its an engine the world forgot about, you cant even get some bearings for it. As niche as it gets. Want a custom intake made? Design one and find a company to make it
I really like this. If I had money I would look at a swap into a lighter vehicle. That running engine/t ranny on a pallet in the classifieds is temptingYour best bet is to ask blue turd if he has one laying around or knows a good shop to modify yours. Or find a lightweight car to put the engine into like an rx7.
I was thinking the same thing about that pallet set up.I really like this. If I had money I would look at a swap into a lighter vehicle. That running engine/t ranny on a pallet in the classifieds is tempting
Driving around a pallet could be interestingI was thinking the same thing about that pallet set up.
Light weight. Would be as aerodynamic as palletDriving around a pallet could be interesting
