hub essembly
krupt89
Barrington RI
Well my wheel bearing went the other night, snapping the axle bolt in the proccess. My Q is can i go to the junk yard and get a loaded hub essembly from a SLO and bolt it up?? or do these parts differ from the SHO and the SLO? Also does anyone know if the axles are the same to? TIA
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The knuckles are the same as a SLO but since you have a 95 you can only get them from a 94-95. Also make sure they have ABS as some SLOs did not.
This would be a good time to get the 96 brake upgrade.
Also if you can afford it would get new bearings pressed in so you do not face this problem later on.
The axles are different.
The lower controls arms are different, just to let you know.
krupt89
Barrington RI
Thanks for the reply loudsho, i figured the axle might be different. Looks like its time to start hunting in the junk yard :banghd:
