How can you tell if a timing belt tensioner is bad? My timing belt had some play in it in between the cams. Normal? about a 1/4 to 1/2 inch of play. I was thinking that my timing belt may have jumped and unfortunatley I moved the crank after I took the belt off so I couldnt see what my timing was at my belt looks fine no teeth are missing and its not chewed up. Also what is the compression supposed to be on the 3.2L and what could make it run like shit I have to keep on the gas at like half throttle otherwise it dies and it has no power. Someone said that the fuel injectors tick when they go bad???
