Thinking of putting in high temp brake fluid. Is it as simple as opening the bleeder screws, pumping out the existing fluid using the brake pedal, and refilling then bleeding?
I was thinking I could open the bleeder screws and pump out as much as will come out, then let gravity do the rest while I replace my rotors and pads.
