How To Heel and Toe Downshift
RonPorter
SHO Club of America
Lake Orion, MI
Yep, in the perfect world where the pedals are near the same height, the "side shoe" method can work. Haven't owned a car YET where that works!! Usually the "toe on brake, heel on gas" works for most cars.
And for cars with worn synchros, rev-matching first in Neutral before hitting the lower gear can help. Just adds to the complexity, though!
kevinspann
Don't take my advice.
Richmond VA
I can't really do it in the SHO, the pedals are just set up wrong. I had better luck in a Focus with it, I could roll the ball of my foot over to tap the gas while on the brakes.
Racer X
SHO Pilot, Retired
Connecticut
Agree, either my feet aren't big enough, or it's just a massive PITA to heel/toe in a SHO. At least it is with the stock pedals, anyway. Maybe I need wider shoes...
K-Dawg
Treasure Coast, FL
I've found it to be easier with narrow shoes. The wider shoes kept getting hung up under the gas pedal when I'd try to roll my foot over to blip the throttle.
thebigjimsho
LSA = YUM
Worcester, MA, USA
I do it anyway...
dohcsable
Gold Calipers>*
Indiana
I can do it in both bimmers, but not the sho's. They're in a too clusterfucked layout.
intimdatr
Got Cams?
Jefferson City, Missouri
I must be an odd one. Ive never really had issues doing it in the SHO. Its sort of awkward at times due to the pedal setup but it's do able.
RonPorter
SHO Club of America
Lake Orion, MI
I don't even bother as I have so many other aspects of my driving to correct/focus on.
A good article none the less.
-Sam
Yep. If you have decent synchros, you can be lazy!!
Occasionally I will do the gear-to-neutral, then blip it, then downshift if I'm going down more than 1 gear.
hawkeye18
Sorta cares
Norfolk, VA
The '11+ Mustang is actually exceptionally well set-up for side-shoe heel-toeing. It's so easy I find myself doing it going into corners without even thinking about it.
markmoomnu
